First thing is this wire (Arrowed) Where the red circle is the wires are brown. From memory I think this wire is to go to earth, but could someone confirm please
Next is what I guess is the heater control valve on the M52. What controls this? Guessing its the hot/ cold heater control knob in the car, so hence if its on cold it actually stops the hot water entering the heater matrix? Going on this, I'm guessing the water flows out of this valve and into the heater matrix, returning to the engine on the other pipe with no valve on it?
Next the Power block on the E36 located on the Offside inner wing:
Connections A, C and E look like they are joined together, and B and D look like they are joined together
The connections on A and B come from the rear of the car, and E goes to the engine loom (and possibly out the other side to the fuse box.)
So effectively the fuse box is live all the time, is this right?
and connection B isn't connected to anything. Surely it should be?
Next.... E36 M3 Evo... Which is the in and which is the out of the heater matrix?
And finally!
What is this? (also on My E36 Evo)
I've looked up the part number (6411 839 1470) on RealOEM and apparently its only fitted to an E38:
http://www.realoem.com/bmw/showparts.do ... g=60&hl=30
Many thanks
Andy
