a while back, I had water coming out the exhaust, so much so that my wastegate was full
so I pulled the head but couldn't see anything obvious, so sent it off for pressure testing and it came back with a clean bill of health,
but the guy said it desperately needed a skim, because it was like a donkeys leg
and it was
so it was done,
it was put all back together and now there is no water coming out the zaust
came to the conclusion that the head could of been "lifting" when I was "on boost"
so gave the ARP's an extra 5 ftlb
but now that's it's all up and running again after some injector issues,
I'v got some serious overheating issues going on,
I was out in it today, didn't get very far until the heater matrix exploded and dumped all the boiling water onto the passenger footwell
popped the bonnet and the top pipe was like a balloon,
cracked open the bleed screw (E36 radiator) and it was just an abundance of air screeching out,
So, me thinking it must of just been the heater matrix letting in air,
I joined the 2 pipes together that go to the matrix,
put it all back together again, bled it, and bled it to the point I know for certain there was no air at all in the system,
Let it sit on idle for a while, and it all looked good,
but by the time i got to the petrol station and back, (under a mile)
opened the bonnet again and the top hose was ballooning once again,
I'v checked the water pump and it still looks brand new, with no play in it at all,
the thermostat is spot on
the Pusher fan is kicking in at 80 degrees
bought a new radiator cap,
I'v had the reservoir off the side of the radiator and i did find what looked like a tiny little crack at the top of it,
but on further inspection, and dumping it in the bath, while blowing into it,
the crack doesn't go all the way through the thickness of the plastic,
so it's not leaking from there,
I'm waiting on a new one turning up just for peace of mind tho,
urm, what else
all the pipes are split free
there is no water dripping from anywhere.
and the gasket is a thick MLS type
when the new radiator arrives and it turns out not to be that..........
anyone got any suggestions ?
