e30 m50 swap Servo
Jamie8GTi
Post Thu May 09, 2013 10:08 pm
Hello after owning a small 316i for half a year the time finally came to liven her up! i got myself a non vanos m50 engine with just over 100k on the clock! :)
as its currently on small discs and useless drums I'm starting on the brakes first and believe the e30 325i rear arms are the best way to go! then 325i callipers and discs on the front.
But my main question is..
i've removed the old bmw servo and pulled out an old mk2 gti's from a mates garage.. now i know people have used these before but the arm through to the master cylinder is shorter on the mk2.. could i just use some sort of round bar? as a floating spacers or would this be a bit dodgy and need tacking on the end
cheers
jmc330i
Post Thu May 09, 2013 11:14 pm
A spacer between the pushrod in the servo and master cylinder is exactly what you need with the Mk2 servo (and the now favoured Clio servo).
A cut down bolt will do the job, but a decent bit of round bar would be better. The length needed does seem to vary a little, but with some trial and error you should get it right.
No need to tack it on, once you have right length it won't be going anywhere.
James
'91 325i Sport
'93 318i touring 16v
Jamie8GTi
Post Thu May 09, 2013 11:26 pm
i was mainly worried about it getting stuck or jamming up, thanks mate!
jmc330i
Post Thu May 09, 2013 11:41 pm
Nothing really for it to jam against. Just make sure the spacer is a good fit in the end of the master cylinder and long enough so there is no slack between the servo rod and master cylinder and it will be fine.
James
'91 325i Sport
Restlesssoul
Post Thu May 23, 2013 7:29 am
Can anyone tell from what year Clio should be that break servo??
jmc330i
Post Thu May 23, 2013 8:03 am
The plastic wing ones, I think around 2001.
James
'91 325i Sport
Restlesssoul
Post Thu May 23, 2013 8:08 am
Thank you James :cool:
flashBE
Post Sat Jun 01, 2013 11:53 am
Does the Clio servo bolt on to the firewall without any adjustments?
balilu91
Post Sun Jun 02, 2013 9:11 pm
It should bolt on to the firewall with no adjustments
flashBE
Post Mon Jun 03, 2013 10:51 am
Great, thanks
flashBE
Post Tue Jun 04, 2013 6:23 pm
8200192612
Is this the right one? Clio 1.2 2003
balilu91
Post Tue Jun 04, 2013 9:41 pm
i will check tomorrow if i can find a part number on mine. but the one i got was from a clio 2.0 16v 2003
Jamie8GTi
Post Thu Jun 13, 2013 4:57 pm
the clio mk2 i believe.. the one made in 2.0 sport and 182 cup
