m52 engine number
Quaser
Post Wed May 01, 2013 8:47 pm
hi
can someone pls tell me where the engine number is on an m52 engine.
thanks
Post Thu May 02, 2013 8:15 am
On the lower edge of the block under the starter
Quaser
Post Thu May 02, 2013 8:18 am
thanks
Quaser
Post Thu Jun 06, 2013 12:35 am
ive looked but cant find it - do you have pics by anychance?
Quaser
Post Thu Jun 06, 2013 12:46 am
basically I need to confirm that its a 2.8 engine and not anything less - the flat bit is blank on mine - any other identifiers?
rich318i
Post Thu Jun 06, 2013 12:52 am
should be a sticker on the back of the head above the flywheel
Quaser
Post Thu Jun 06, 2013 12:53 am
unfortunately, engine is already fitted to the car :(
rich318i
Post Thu Jun 06, 2013 1:05 am
check the ECU numbers be more easy???
http://realoem.com/bmw/partgrp.do?model ... g=12&fg=10
Nas80
Post Thu Jun 13, 2013 6:27 pm
You need to scrub it clean because alloy oxidises. Theres a flat square bit just near the mount. The bottom row of numbers need to start with 2 8
