I have an erratic idle and some other symptoms on my M50. Not to go into too many details I have some technical questions which I'm hoping someone might be able to answer.
1) Whilst installing the engine (when it was working) I noticed that it will run quite happily (Limp mode I think) with the MAF sensor disconnected (electrically). What other sensors does the ECU use to make ICV adjustments when the MAF is disconnected??? (There is no intake pressure sensor that I know of)
2) What could cause the revs to stay high for 1-2 seconds after the throttle is released (closed), I've tried 2 different TPS's and 2 different ICV's. I'm thinking vacuum leak in manifold post-ICV. (Symptoms get worse with MAF disconnected).
M50 Idle - Technical Question
Do you have all sensors connected? You need to make sure its out of limp before worrying about idle speeds etc
gudgeon
The question is, how does the ECU control idle speed when the MAF is disconnected? I know it does, 'cos I've tried it.
Think I've solved the problem now, just curious about non-MAF operation.
Idle speed control is essentially a simple feedback loop from the ECU's engine speed signal to the ICV. MAF doesn't come into it.
