Bleeding Cooling system on M52 ( Auto )
Ianb
Post Wed Jan 09, 2013 2:04 pm
I know these are a bitch to bleed when in an e30 but I'm trying to bleed my e36 328i and am a little nervous because when i did the e30 I jacked the front really high and had to run the car at high revs for ages and all the advice i've had about the auto box is not to rev it in neutral - does anybody have any idea if reving it in neutral / park to about 2k revs will do the transmission any harm ? Thanks
e36bmw12
Post Thu Jan 10, 2013 11:27 pm
i dont eva jack my e30 up with 2.8i in it get a bit of pipe about 6 inches long that will fit in snug where the water razor wire cap goes start by taking the top rad pipe of just the rad then start putting water in down that pipe intill it starts cumin back out of the pipe reconnect pipe to the rad do all this with cap of an bleed screw undone once rad pipe reconnected fill rad right up with water put ur bit of 6 inch pipe in rezor wire cap hole an start blowing in to the system remember to have bleed screw lose keep blowing till all the air bubbles stop coming out of bleed screw titan bleed screw up squeeze all the pipes on the rad then make sure water level still ok then undo bleed screw again whitest blowing down the pipe just to make sure theres deff no more air in there then start your car with heaters on full run it up to temp makeing sure your heaters are warming up it works every time takes less than 5 mins good luck
Quaser
Post Wed Jan 30, 2013 9:18 pm
^^^^ what he said - got it perfect first time when he helped me with my conversion
