m52 + 6-Speed box
Post Sat Dec 22, 2012 1:31 am
what's involved guys and expected costs .
i've got an m42 box sat waiting for the m52 swap but i'd like to have a 6-speed set up in the real world .
Post Sat Dec 22, 2012 9:36 am
Cheapest way to do it is S50 box- £400 odd, custom prop- £150 odd, custom gearbox mount, you should have everything else
Post Sat Dec 22, 2012 11:27 am
cheers Dan .
HairyScreech
Post Thu Dec 27, 2012 5:25 pm
And i just so happen to have a known good S50 box here, only removed to go 5 speed for a track compact.
turk
Post Thu Dec 27, 2012 5:28 pm
If u can find a E46 325d box, it needs a custom mount.
No need for custom prop, an e46 auto front end fits straight it and works with 6 speed lengths.
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
HairyScreech
Post Thu Dec 27, 2012 5:33 pm
Are those generation boxes the fine spline input shaft though?
turk
Post Thu Dec 27, 2012 5:40 pm
HairyScreech wrote:Are those generation boxes the fine spline input shaft though?
Good point, It will need a friction disc to match the spline.
I have a new one you can have for a drink + postage
Sump Baffles
TrackDays
HairyScreech
Post Thu Dec 27, 2012 5:43 pm
We really all need to put our heads together and figure out a solution to the later fine spline boxes with a solid flywheel. (which i think magpie may have?)
turk
Post Thu Dec 27, 2012 6:05 pm
E36 m3 lightweight fly
E36 m3 pressure plate
E46 thin spline 240mm friction disc
E46 6 speed box
E46 325i auto front prop
Custom mount and shifter.
Tried and tested with an s54 power. Worked great apart from the dodgy box I used which had loads of play.
Sump Baffles
TrackDays
SteSE
Heading for the Naughty Room
Post Sun Dec 30, 2012 5:50 pm
This dude had a decent thread on 6 speed boxes on e30tech but i can't find it
87.5 Impact FM
PS3: gary_bunter
1986 325i resto - M52'd
C plates are fastest
Post Sat Apr 27, 2013 7:54 pm
mr screech do you still have this g/box ?
randomspeedfreak
Post Sat Apr 27, 2013 10:23 pm
turk wrote:E36 m3 lightweight fly
E46 6 speed box
how does the e36 fly compare to a lightened m20 one?
cheers,
Matt
Post Sun Apr 28, 2013 1:58 pm
E46 6 speed box
cheers,
Matt
Unless its an ally flywheel it will be heavier
