m50b25 conversion help
Antoe30
Post Mon Nov 19, 2012 5:05 pm
Had planned to do the m52b28 conversion but had trouble with the engine so came across a full 1995 e34 525 so bought it very cheap.
So I have the e34 sump, oil pick up and dipstick already attached, along with the m50 inlet. As far as I know I use e36 engine mounting arms? and I'll be using e28 m5 engine mounts. Il be getting the brake servo from a plastic winged clio. Need help deciding what box, prop and diff to use? And some help figuring out the wiring and the other small bits a pieces?
Rancid
Post Mon Nov 19, 2012 6:07 pm
Plenty of info here: http://www.e30zone.net/e30zonewiki/index.php/M5x
IIRC M42 gearbox, m20 flywheel (lightened) and m20 clutch are the preferred combination.
HTH
Formerly known as Rancido64.
e30less at present, working on that one....
-> Xbox360 Halo freak, GT: a wild Rancid
Mobile Phone Technical Support:
Got a problem with your mobile phone?
PM me and I'll do my best to help :)
