Hi All,
Quick question. Has anyone done the M52 conversion and fitted a viscous fan rather than electric?
Thanks,
Bhups
Viscous Fan
What viscous did you use? I have the diesel one.willnz wrote:I have both.
Clearance is tight (about 30mm) so I have fitted a restraint between the gearbox and body to prevent the motor moving foward under heavy braking and having the viscous hitting the radiator.
