ccv dipstick tube.
Sx279
Post Sun Nov 04, 2012 4:47 pm
ive got a 328 engine on my old dipstick there is the ccv but on my new e34 stick there is not a pipe to connect it to.
what options do i have hear?
what has evryone done to get around this?
thanks
Post Sun Nov 04, 2012 6:21 pm
Get rid of the separator and pipe up the crank case breather as per M50
Sx279
Post Sun Nov 04, 2012 7:18 pm
Sorry what do you mean pipe up the crank case breather?
My understanding is that the pcv valve is to get the blow by gasses out of the crank case back in to the intake route.
With out a breather in the crankcase wear would all the gasses go?
Also if I was to hav a catch tank would it be set up that I have cam breather and crank breather to the tank then to atmosphere and block off the hole in the intake wear the gasses would return?
Post Sun Nov 04, 2012 7:57 pm
Its to separate the oil from the gas, and by doing this it destroys itself because the oil rots the rubber diaphragm and causes air leaks.
Read this for m50 manifold info - http://www.e30zone.net/modules.php?name ... c&t=181824
Sx279
Post Sun Nov 04, 2012 8:20 pm
So the crank case can breath through the cam cover breather cos the chain area connects the two?
So I don't need to weld the breather pipe on the new dipstick just do away with the seporator?
Sx279
Post Sun Nov 18, 2012 10:05 am
anyone?
Post Sun Nov 18, 2012 9:53 pm
Yes. Getting rid of the PCV valve is an upgrade in itself.
rich318i
Post Sun Nov 18, 2012 11:32 pm
all i did was got my M50 dip stick to match the M52 spec. cut and weld. my M52 is like factory spec with M50 manifold
Sx279
Post Mon Nov 19, 2012 10:17 pm
can any one tell me what this is?
and is this the valve for the heater matrix?
also dos this connect to this?
thanks
kevo
Post Mon Nov 19, 2012 10:41 pm
the first one is the charcoal canister that your fuel tank vapour pipe connects to but it's not really required on your conversion unless your particularly a 'greenie' (environmental saving person lol)
the second one is the e36 heater matrix valve and is also not required to fit this engine to your e30, it's part of the e36 heating control side.
the third links don't work for some reason?
cheers
Kev
Sx279
Post Mon Nov 19, 2012 11:05 pm
thanks mate na don't need the hippie box haha, ill just blank off the nipple that it connects to is that in the manifold?
these two pictures are the ignition coil loom.
i think i am missing a piece of loom that connects these two if they do connect if not wear dos it connect to?
thanks for all the help.
