Has anyone tried the e28 m5 engine mounts from euro carparts?
The 335 e28 mounts do they clear the Clio brake servo without spacers?
Also when using a Clio brake servo do you have to install the servo befor or after putting the engine in?
Engine mounts and servo
Jimbob
I think I might've ordered the e28 mounts from ECP but had to swap them as they didn't seem right - got them swapped for e24 mounts in the end.
It would be 100 times easier if you changed the servo with the engine out.
Sx279
Hi jimbob.
So the e24 mounts worked then what model was they from (e34 1.8 2.5???)
Chears mate
Chears mate
