Timming out
Jozi
Is it a big job to correct the timing on a m52? It looks like the chain has jumped on me and put the timing out.
Supafly
It's not too hard to time these up. It also is heavily dependant on your experience and or willingness to give it a go. Do you know why it has jumped?
I think I used a few links on line to make sure mine was timed up ok. One of the best sites I used was the pelican parts website. If you have an m20 flywheel then you won't be able to lock the flywheel but even then it isn't that bad.
Good luck.
Good luck.
