Some questions - PS pump, Bracket & wiring
Jozi
Post Fri Aug 24, 2012 3:37 pm
I'm putting the engine back together and finding small problems and the like holding me back.
First up, should I be using a m50 or m52 PS pump? I went to fit mine earlier and there's a hose which clashes with the sump if I try to fit it in the correct position.
I also have this little bracket left over that I'm not sure of where it goes:
And what plugs into these two guys on top of the manifold?
I have one connector on my engine loom that looks like it could go there but I don't think it fits around that way and is for a temp sensor?
Also is this connection correct:
Cook318IS
Post Fri Aug 24, 2012 5:25 pm
You should use whichever pump fits with the type of oil filter housing + alternator you have. Ie, an m52 housing should use and m52 p/s pump and an m50 housing should use an m50 pump. I fitted an m50 oil filter housing and alternator to my m52 so i'm using an m50 p/s pump without any issues.
I can't say i recognise where the bracket goes.
The plugs ontop of the manifold are for the lambda sensors (i always forget which one plugs to which manifold!)
The last pic - yes, the vanos solenoid plugs into the end of the injector wiring cover.
Jozi
Post Fri Aug 24, 2012 6:26 pm
Everything there is from the engine in the pics except the sump, it's a 5series engine so maybe the pump was a little bigger cause the e39 is heavier than a e36?! I'll look into getting a pump from a e36 if I can make this one fit.
Anyone know which order the lambda's go in? I thought I lost them both but found them on the old e39 loom.
Bracket seems to go to the read of the block for the lambda wires.
e30-EVN
Post Fri Aug 24, 2012 11:18 pm
the back plug is for the front manifold lambda, the front plug is for the rear bank lambda 8)
e30-EVN
Post Fri Aug 24, 2012 11:34 pm
the connection in your last pic is correct Brend, its for vanos solenoid and plugs into the end of the plastic wiring rail how you have it in ya pic :)
