Makes sense anyway though as after driving it recently I thought it wasn't pulling quite as well as it used in the top end as it did before when I put the engine into first or fitted the M50 inlet
took it apart now but I can't find the part numbers on realoem or anywhere for rebuilding it and I need it back together fairly quickly.
Probably just not looking hard enough or if somebody has all the bits lying in a corner ready to go, it would be quite handy too... Dan?
