Running Temp of a M52
andyborris
Post Sun Jul 22, 2012 8:44 pm
Anyone know the normal running temp of a M52 engine?
Andy
Post Sun Jul 22, 2012 9:55 pm
An E36 328i thermostat is 92 degrees
andyborris
Post Mon Jul 23, 2012 7:06 am
Thanks Dan.
Post Mon Jul 23, 2012 2:10 pm
I would advise running the system at 2 bar in an E30, with a 92 degree 'stat in a M52.
It's very possible that local boiling could occur in the head at 1.4 bar.
Post Mon Jul 23, 2012 7:01 pm
80 degree stat is what I use
SteSE
Heading for the Naughty Room
Post Fri Jul 27, 2012 5:02 pm
Where should an M52 engine / coolant temp register on an e30 temp gauage?
87.5 Impact FM
PS3: gary_bunter
1986 325i resto - M52'd
C plates are fastest
Post Fri Jul 27, 2012 7:38 pm
Depends what temp your running it at, 80 degree sits at 1/4 and 88 degree centre
e30-EVN
Post Fri Jul 27, 2012 10:38 pm
mine sits on half with 88 degree stat, gets up toward 3/4 before fan comes in when in traffic.!
im getting an 80 tomoro so she runs cooler in this hot weather
SteSE
Post Fri Jul 27, 2012 11:14 pm
Cool. Thats what mine does. They run hotter than the M20s, I don't remember that moving on the temp gauge at all.
If these get into the red is that it?
87.5 Impact FM
PS3: gary_bunter
Post Fri Jul 27, 2012 11:17 pm
Viscous fan is the difference.
e30-EVN
Post Fri Jul 27, 2012 11:18 pm
mine has never got to the red, fan comes in and stops that happening. i wouldnt want my m52 to reach the red.!!
SteSE
Post Fri Jul 27, 2012 11:20 pm
But she doesn't fit! I've been reading horror stories of m52s getting hot and I'm paranoid! :cry:
87.5 Impact FM
PS3: gary_bunter
e30-EVN
Post Fri Jul 27, 2012 11:24 pm
best way to go is 80 degree stat and 80-88 degree thermo switch with a decent electric fan.... you wont have no worries then mate 8)
Post Fri Jul 27, 2012 11:35 pm
This /\
slim91
Post Fri Nov 15, 2013 6:11 pm
What stat would I order do they do different one for e36 or do I get a different one? Cheers
Post Fri Nov 15, 2013 6:21 pm
80 or 88, just ask them to check the temp at wherever you buy it from
AndyZippy
Post Fri Nov 15, 2013 8:34 pm
Mine is running an 88 deg stat, and is fine, though i think i might grab an 80 instead.. not totally convinced she'd be super happy if in traffic for a longer time
rich318i
Post Thu Dec 05, 2013 8:23 pm
DanThe wrote:80 degree stat is what I use
What cap Dan. 2 Bar or 1.4 Bar ?
Running a 2 bar and 80 stat
Post Thu Dec 05, 2013 8:57 pm
If the engine is in an E30 with an E30 heater valve then you should be using a 1.4 Bar cap
rich318i
Post Thu Dec 05, 2013 9:05 pm
DanThe wrote:If the engine is in an E30 with an E30 heater valve then you should be using a 1.4 Bar cap
cheers
Opps been using the 2 bar.
matrix or heater pipes or both have gone . 30 months on from the conversion :cry: :cry:
dropping to my local dealers tomorrow and see if i can get my free cap from them if the cars not already had one
Post Thu Dec 05, 2013 10:03 pm
Same valve in an E30 iS, and that works happily at 2 bar.
rich318i
Post Thu Dec 05, 2013 10:08 pm
think mine is just due to old age then. It was a 318i before the m52 conversion
That or the 2 bar cap is not working and blown the matrix still have to find out but will be getting a new cap once the work has been done any way just to be safe
Is their away to test the cap if its fooked??
craigieeb
Post Thu Dec 05, 2013 10:33 pm
squeezing the top pipe and listening for air around the cap normally works
rich318i
Post Thu Dec 05, 2013 11:15 pm
cool cheers
Post Thu Dec 05, 2013 11:38 pm
rich318i wrote:think mine is just due to old age then. It was a 318i before the m52 conversion
AFAIK, the 2 bar cap isn't involved in the recall; just the 1.4 version.
No way to test the cap. The problem is that the pressure release valve very occasionally sticks shut in old age, over pressurising the system and exceeding the pressure limits of the weakest part, the electric heater valve.
Quaser
Post Fri Dec 06, 2013 12:48 am
has anyone got the part number for the 80/88 temp switch pls?
Post Fri Dec 06, 2013 9:03 am
61 31 8 361 787
Post Fri Dec 06, 2013 9:07 am
Ahh ok, I thought they changed them all to 1.4 with the recall, thanks Brian
Quaser
Post Fri Dec 06, 2013 11:07 am
And a part number for 80 degree thermostat pls
Motorhole
Post Fri Dec 06, 2013 3:01 pm
So should I be running using a 1.4 or 2 bar cap in my m52? Any probs with running a 1.4 bar cap, using the 80-deg stat? I'm using 2 bar at the mo.
Post Fri Dec 06, 2013 7:25 pm
Running the engine way below its design temperature at 80 degrees will reduce its efficiency, but will allow you to run a 1.4 bar cap. The idea is to run an engine as hot as possible without any local boiling in hot spots occurring.
