EWS question
Driftybolox
Fri Jul 06, 2012 1:21 pm
Hi guys,
Have found a cheap, crashed 328 E36 and am thinking of having the engine for my E30. The car doesnt have keys, so no chip etc. for the EWS.
Now as my car is a track car, I have a separate wiring loom for everything. Fuel pump is on a switch, starter is wired directly etc. If I do the same with the E36 ECU... i.e. just give it power and earths where required, will this bypass the EWS?
Thanks in advance
James
Fri Jul 06, 2012 1:41 pm
Nope, but you can have the EWS requirement deleted from the ECU, send me a pm and I can do this for you
Driftybolox
Fri Jul 06, 2012 2:02 pm
Awesome. So if I was to fit some throttle bodies I've got lying around, you could also map the ECU to suit?
e30-EVN
Fri Jul 06, 2012 7:46 pm
I've had the ews delete and remap service danthe provides and I would highly recommend it 8)
BATTS91
Sat Jul 07, 2012 10:55 am
i wouldnt fit throttle bodies tho , m50 inlet boss
Driftybolox
Mon Jul 09, 2012 10:02 am
M50 inlet won't give me the same trouser tent noise that GTR throttles will...
It's stuff I have lying around as I work for a Skyline breakers. So only needs my time to make up a manifold
