Right my M50 seems to have got a problem!
It will start first time everything when it's cold, but if I go for a spirited drive for 30+ mins go for a pint and come back to it 30mims later it will not start........
If I keep repeatedly cranking it 10 times+ then it will sort of start but it doesn't inspire confidence.
Has anyone got any ideas please.
Mark ;)
M50 2.5 hot start issues! Any ideas people???
Jibberingloon
randomspeedfreak
just a guess but sticking fuel pressure regulator?
or some other fuelling issue
does it splutter when its cranking?
does it kick into life like normal after cranking it on a hot start or splutter and eventually go?
will it hot start if you dont go for a pint and try it immediately?
Jibberingloon
FPR... hmmm
Doesnt splutter just crannks and cranks and cranks
Thenon abour 4th attempt at cranking it starts with a slight splutter.
If I leave it for a few minutes it still does this but not as bad as leaving it for 30mins +
Anyother ideas?
Ive been reading and someone said engine temp sensor?
Anyother ideas?
randomspeedfreak
if it was engine temp id expect issues whilst running aswell?Jibberingloon wrote:FPR... hmmm
Anyother ideas?
it sounds like the fuel system is de pressurising then taking its time repressurising
is an m50 manifold fitted?
if so and you are on high load for a long time does it lean out and missfire?
have you checked that your ews is clicking at the right time? if it was sticking or something i guess it could be possible that it would stop it starting....but then again that wouldnt explain the difference in the time it takes to start, after you have left it for a shorter amount of time
im no expert by the way mate im just having a dig
Jibberingloon
Hmm
No EWS
Its a M50 engine anyway so yes it has the Manifold ;)
Doesnt seem to lean out, and I dont have any misfire!
But if the the fuel tank depressures, sure I would have a cold start issue aswell!
Cold start is perfect everytime.
I am very confused.
No EWS
I am very confused.
Indeedy, biggest give away of the blue sensor is hot running problems, perfect when cold, crap when hot. Ive had engines even cut out once they have warmed up because the sensor has been so badJibberingloon wrote:
Jibberingloon
Will replace the blue sensor then ;)
Where can I find a part number?
Cheers Mark
Cheers Mark
