new spark plugs make it pop in idle
rich318i
got new plugs and they make it pop in idle and the old ones dont, any ideas?
deanocool
what plugs have you fitted? Ngk BKR6EK?
rich318i
yeah mate and the old ones were as well ,cant under stand it. you had the same prob?
deanocool
have you plugged the coilpacks in the correct order and locked them on? i changed mine and had no probs dude!
fixedwheelnut
Basics but have you checked the plug gap? if they are too small you get a short burn and erratic idle.
deanocool
ngks come pre-gapped so unless hes knocked the electrode on one or something..they should go straight in no fuss
bhups
I had this problem with NGK's then we put in Bosch plugs and it was fine with those.
rich318i
took them back and they exchanged them for a new set and still done it so it chould just be the NGK's
deanocool
i very much doubt its just because theyre ngk manufactered plugs. i sell 30 odd off them on a good day (especially bkr6ek's) and theyre spot on. they are much more reliable than the bosch or champion plugs we used to sell in the past. add that to the fact you had ngks in before and it was fine..... you havent messed with anything else on the car have you? think back......
rich318i
100% mate even put the old one back in and it didnt do it, put the new ones back in and guess what! lol
Alpina recommend the BKR6EK plug
Are you sure thats the plug number you have been sold?
rich318i
100% mate got them from c3bmw instore and they gave me another set and it still did it
rich318i
but why the old plugs dont do it its a mistery!! and they was well gone at the tips
Cook318IS
Same as Bhups for me and my m52. Was fine on boschs, changed to NGK and a light misfire + very slight hunting on idle and it wasn't pulling as well as it was on the boschs. Put the boschs back in and it was fine.bhups wrote:I had this problem with NGK's then we put in Bosch plugs and it was fine with those.
rich318i
it flys with the new plugs but pops abit on idle, its a mad why new plugs should do thisCook318IS wrote:Same as Bhups for me and my m52. Was fine on boschs, changed to NGK and a light misfire + very slight hunting on idle and it wasn't pulling as well as it was on the boschs. Put the boschs back in and it was fine.bhups wrote:I had this problem with NGK's then we put in Bosch plugs and it was fine with those.
fixedwheelnut
Check the leads, the end caps can get pulled off if they are tight coming of.
deanocool
weird. cant see why one set of knackered bkrs dont pop and 2 new sets do? as said i changed mine over on my m50b25 no probs not for any reason other than a typical service. ive just changed the mrs m52b28 plugs for ngks to sort a misfire i had with boschs, although they were battered and any plug in that shape i would expect to miss. how annoying. the easiest thing then would be to stick in a set of bosch plugs, see what it does. can they get you a set in?
rich318i
even put coilpack 6 to 3, 5 to 2 and so on and still did it so they are sweet, its just a jar but the engine is sweet, got a sneeky feeling a o2 sensor is on its way out
fixedwheelnut
Just realised you are not running an M20 if you have individual coilsfixedwheelnut wrote:Check the leads, the end caps can get pulled off if they are tight coming of.
Are the earth wire connections good for the coils?
rich318i
yeah mate pulled every coil out one by one and it runs ruff so they are working
Supafly
I had a similar problem on my old m20, new ngk's about a month old and caused a misfire and terrible running after a minute from cold. Wound up checking and changing all sorts for it to finally be fixed by a set of bosch plugs.
So you can add me to the list of people who have had a dodgy set of ngk's.
rich318i
think ive sloved the problem in my case let you all know tomorrow
eko
- Old timer
What have you done to cure it?rich318i wrote:think ive sloved the problem in my case let you all know tomorrow
deanocool
lol i take it from your smiley that youve looked back??deanocool wrote:you havent messed with anything else on the car have you? think back......
rich318i
it stalled on me the other night twice so took the idle value out to clean it. when i put the m50 manifold on.. we, well i put the valve on on the wrong way round (dont ask). but does it still a tiny bit but need an new o2 sensor the computers coming up with but no more 5500rpm limp mode did the speed signal today and it flys. But why its fine with the old plugs its crazydeanocool wrote:lol i take it from your smiley that youve looked back??deanocool wrote:you havent messed with anything else on the car have you? think back......
rich318i
UPDATE UPDATE: o2 sensor was fooked put another one in today test drive tomoz. oh and i need a new cluch, slipping like a burning a bitch
