m50 misfire
calex
Post Sat Dec 24, 2011 7:15 pm
Just put an m50 into my 318i and it runs realy lumpy and has a misfire and flat spot between 1000 and 2000rpm. Seems to work fine flat out, and it also idles erratically and cuts out every time i stop. I had never driven the doner car but i dont remember it running that poorly or i wouldnt have used it. Any suggestions would be appreciated.
randomspeedfreak
Post Mon Dec 26, 2011 11:48 pm
I have the same problem-interested in the answer
GemE30
Post Tue Dec 27, 2011 12:04 am
Sounds like it could be an air leak, inlet manifold seals or inlet pipe, vaccuum hose or anything.
blue30
Post Tue Dec 27, 2011 3:37 pm
Check grounds
Check lambdas
Check MAF
Post Tue Dec 27, 2011 7:02 pm
check that the swan neck type rubber pipe that goes from the idle control value into the back of the inlet manifold is seated correctly, there is a little stub that comes off the pipe too, check that is blocked off
http://www.e30zone.net/modules.php?name ... c&t=181824
