Using an m50 dual mass flywheel and clutch with an m40 box?
be11
Post Sun Dec 11, 2011 5:51 pm
I offered my m40 box up to the m50 today. It's currently got the standard dual mass flywheel and a paddle clutch fitted.
Everything seems to fit fine. Bell housing offers up fine, input shaft spline on the box is the same as n the friction plate and e34 starter motor also bolts up fine.
Am I going to have problems with the clutch release bearing and slave cylinder not releasing the clutch properly.?
Has anyone else used this combination? I don't really wanna go spending lots of money on an m20 flywheel and new clutch.
Post Sun Dec 11, 2011 6:18 pm
Will work fine with the standard release and slave
be11
Post Sun Dec 11, 2011 6:27 pm
Fantastic just want I wanted to hear. Thanks dan
