No power at fuse 11
Baurluvva
Post Sun Dec 11, 2011 2:48 pm
I am having some teething probs....
No power at fuse 11 on m52 install
I believe that the c101 plug is wired up correctly but I still have the ews outside the car as I think the problem lies there?
Browns to earth
red/yellow to const live
blues to each other
purple and white to live in acc ( any preference of colour wire to attach it to?)
Why do I not have power to fuse 11???
Post Sun Dec 11, 2011 3:05 pm
You realise you only get power there when the crankshaft is rotating?
Baurluvva
Post Sun Dec 11, 2011 3:25 pm
No!
I'm having issues with no fuel pump working and read through other threads stating there would be power at fuse 11 for fuel pump feed!
Confused :?
Post Sun Dec 11, 2011 6:23 pm
When you turn the key to ignition the pump is powered for a few seconds to prime the system, regardless of EWS or any sensors it should still prime if your wiring is correct.
Bridge the relay then test for power at the fuse if your checking the circuit
Baurluvva
Post Sun Dec 11, 2011 6:37 pm
I am not getting it prime at all - tried bridging 30 and 87 - nothing. Was working fine when I removed the previous lump
Post Sun Dec 11, 2011 9:11 pm
When you bridge 30 and 87 at the pump relay base, the pump should run continuously, regardless of ignition switch position.
First check: Connect a 12 volt bulb between 30 at the relay base (red wire) and earth. It should light.
Baurluvva
Post Mon Dec 12, 2011 3:00 pm
Sorted - main power was not connected ( was on e36 main block but on the switched supply that wasnt connected ) :o:
Just need to confirm...... Fuel pipe feed is upper or lower pipe from car body?
