BBTB's
Green
Post Sat Nov 26, 2011 4:18 pm
I'm just looking at my options here for BBTB's amd just need a few quick questions answered.
I've the m50 mani and TB at the moment installed on mine currently.
What's the largest internal diameter the m50 TB can be taken to?
What's the largest internal diameter the m52 TB can be taken to?
What's the best one to use, pro's and con's if any?
Any other info you know of as well that might prove useful!
Cheers :D
hongkongfuey
Mad-tango-geezer
Post Sat Nov 26, 2011 4:54 pm
I know the m20 ones go from 60-64 mm, so as a guess m50 would be 64 - 68? Dont know how thick the walls are? Even 1 mm off would be 66 mm
with cars like mine,
Green
Post Sat Nov 26, 2011 7:26 pm
I found a couple on ebay by someone in lithuania, M50 TB was 68mm and the m52 was 68.5mm.
I guess that's answered if that's been taken to the max. But is there any performance benefit to refitting the m52 TB with an extra .5mm internal diameter?
Also IIRC you need a metal spacer between the mani and TB if you're fitting the m52 one on the m50 mani. Assuming this can just been a few mm thick as it's just a plate?
e30-EVN
Post Sat Nov 26, 2011 7:31 pm
Just bore the m50 item!
Iirc the rubber gasket on an m50 is on the manifold, its the other way round on an m52........
Hoobs
Post Wed Nov 30, 2011 11:05 am
This one is supposedly 15% larger than stock? I think the internal diameter & butterfly are usually 64mm and this has been taken out to 68.5mm. Obviously it's been cleaned & polished too. It was £110 delivered which isn't bad compared to their m50 inlet which they wanted £557 for! :eek:
Rally Prep - Cornwall
ARM BMW & Motorsport
2002
E30 M3 2.3 - Alpha N, C/F airbox etc
Post Wed Nov 30, 2011 1:07 pm
Which one? :?
Hoobs
Post Wed Nov 30, 2011 6:44 pm
Sorry, which what?
2002
Post Wed Nov 30, 2011 6:58 pm
Pics didnt show earlier.
That looks the same as mine, it was £65 on ebay
Who is selling the extortionate manifold?
Hoobs
Post Wed Nov 30, 2011 8:59 pm
CA I think they call themselves?
I rang because, rather naively, I thought that price was fitted! I almost choked on my coffee when the guy said it was for the manifold alone! I told him I bought mine for £75 and he just said ''good luck getting one for that much'' so I hung up.
It was £553 not 557 or £775 fitted. :mad:
2002
Green
Post Thu Dec 01, 2011 7:25 pm
DanThe wrote:Pics didnt show earlier.
That's a nice price, only one's on there at the moment are about £80/£85 posted.
I might be worth just buying one rather then getting mine worked. Although I could see if the engineering student at college are able to do it for free.
