M20 temperature sensor wiring help required
260MAF
Post Sat Oct 08, 2011 6:45 pm
I have modified my M20 temp sensor to fit the M52 block, but need to know where.how to wire it in. I know I need to connect the brown/violet wire rom the M52 sensor to the M20 sensor, but what about the other wire from the M20 sensor? Would somebody please advise.
260MAF
Post Sat Oct 08, 2011 10:34 pm
Anyone?
Post Sat Oct 08, 2011 10:38 pm
What other wire from the M20 sensor? Should be a single pin sensor which only needs connecting to the Brown/Violet wire
260MAF
Post Sat Oct 08, 2011 10:42 pm
I took the brown sensor from my old knackered M20 engine and the brown plug for it has 2 wires attached.
Post Sat Oct 08, 2011 10:47 pm
DanThe wrote:Should be a single pin sensor which only needs connecting to the Brown/Violet wire
260MAF
Post Sat Oct 08, 2011 10:51 pm
Thanks. I shall look for the correct sensor tomorrow whilst wearing a dunce's hat.
Post Sat Oct 08, 2011 11:30 pm
A very long time ago, M20 'brown' sensors did have two terminals. Unlikely, but it's possible you have one of these.
260MAF
Post Sun Oct 09, 2011 7:44 pm
OK, had a look today. The sensor has 1 pin/terminal, but the plug had 2. I kept the brown /violet one & connected it to the same wire on the M52 loom and removed the brown/yellow wire completely.
I haven't started the car yet, so don't know if it works!
