clutch help
lee
Tue Aug 30, 2011 12:34 pm
about to order my clutch for my conversion.
fitted the m20 flywheel. and using a e36 is box. so whats going to be the best clutch for it?
any one help....
was going to ordfer a 325 e30 kit...will this work ok?
e30-EVN
Tue Aug 30, 2011 12:37 pm
if your using the m20 flywheel you will need the starter motor to match
also my highest recommendation is to get a sachs m20 clutch.. i fitted an luk item to my m52 and its shite!!!!
needless to say the engine will be coming out over winter and a sachs one put in its place. when i did my first 24v conversion it was an m50 and i re-used the sachs clutch from my m20 (second hand) with no such drama but i bought an luk item being tight and its my only regret.... period! 8)
lee
Tue Aug 30, 2011 12:49 pm
cheers dude...did u you use a complete 325 kit or get the release bearing from a 323?
e30-EVN
Tue Aug 30, 2011 12:52 pm
no need for 323 release bearing mate!
i used m20 325 item and its all fine.
if you are using e36 box you need to use e36 clutch slave afaik 8)
lee
Tue Aug 30, 2011 12:56 pm
cheers dude
thank you for your help
