Hi I have done an M50 swap on my e30 the engine is from an E34 5 series and the power steering pump has 2 blanking plugs that would be used if the car had self levelling suspension but as it doesn't BMW fitted blanking plugs to it. The pump leaks constantly from these 2 blanking plugs even though the pump has been reconditioned 3 times now. I have checked that none of the lines are blocked and they all seem clear.
Does anyone have any ideas what the problem could be? Am I using the wrong pump or is it because I have still got the 316 steering rack?
Thanks Matt
M50 swap power steering pump problem
I would just swap another pump in there mate
when i had an m50 in mine it was also from an e34 but didnt have these blanks you talk about?....
you need another m50 pump mate, mine only had ports for fluid in and out!
A 2 door e30 with 8 cylinders, what could be better
Sjoerd320i
Dan, why should he use an e36 pump and not another e34 one?
