e28 535 mounts
lee
Thu Aug 18, 2011 9:49 am
where can we source the mounts?
are there other mounts that can be used for the m50 conversion?
kevo
Thu Aug 18, 2011 10:34 am
i used the standard e36 engine mounts with no issues if you're doing it on the cheap. m20 ones don't give enough clearance btw. and the 535 ones are dealer or ecp i believe.
Kev
lee
Thu Aug 18, 2011 12:39 pm
cheers dude
Thu Aug 18, 2011 1:47 pm
The E36 mounts are very tight on the chassis, you will probably have to force them in (hammer/big bar) but they are prone to failure on E36's
With the E30 subframe having a different angle they will be in twist once you have them tightened up, this IMO will only help them fail quicker.
The best all round mounts I have found are for S38/M30 engines, part number = 11-81-1-128-932
jimbob88
Thu Aug 18, 2011 5:32 pm
I got my 535 mounts from the dealer, £44 each :(
power corrupts.....absolute power corrupts absolutely
My car
Thu Aug 18, 2011 7:22 pm
kevo wrote: m20 ones don't give enough clearance btw.
Nothing a spacer (thick washer) won't solve.
e30-EVN
Thu Aug 18, 2011 9:32 pm
e28 m525 mounts are what ive used... they've had 5000 miles of abuse with the m50 and had hell with the m52 for the best part of 2-3 months now..... they are fine 8)
i would not use e36 mounts, do it properly - do it once :)
