Cold air feed
jimbob88
just looking to see what people are running for filters, feeds, heat sheilds etc. trying to get a few ideas for my intake
spotted these on ebay but they're 92-95, looks like a different maf fitting to me??
http://www.ebay.co.uk/itm/BMW-E36-92-95 ... 519227ae7b
nickso
- Location: Go do that voodoo that you do so welllllllll!!
not keeping the standard airbox then?
'88 e30 328i M52 track bint.
If you don't have ABS then get an early E35 325i M50 air filter box
e30-EVN
on all bmw's the standard airbox is better than most setups...... however if you have abs you will find, like me that you have no room for an airbox! in this case an alternative is needed,,, i have an inclosed filter straight to the back of the headlights, it similar to a bmc item.
it performs fine on my car.
before this i had a normal cone filter as it was the only thing i could lay my hands on, it just kept sucking in hot air and was crap, but this inclosed apnin is great as it has its own heat shield
A 2 door e30 with 8 cylinders, what could be better
e30-EVN
BTW,, if i had no abs unit in the way i would in no doubt fit an m50 airbox
e30-EVN
If you have abs your in the same boat as me mate, inclosed filter FTW
Kristo
e36 325 and e34 525 air boxes are different? or fits e34 box too?
bmwfans.info shows that in e36 is 320 and 325 boxes different too...
e30-EVN
the problem with fitting these mate is the abs equipped cars have the abs unit in the way!
im sure danthe fitted an m30 airbox to one though but recorded higher intake temps with it
jimbob88
think im gonna bin the abs and use /make/find a heat sheild
have you seen these ones over on R3V?
http://www.r3vlimited.com/board/showthread.php?t=185577
e30-EVN
they look bloody awsome mate fair play
but if your binning the abs you will be able to fit a normal bmw airbox....... or are you going for that custom look?
jimbob88
im binning all the brackets and smoothing the engine bay, then painting the engine bay matt black to contrast the newly painted silver engine
, theres a couple of small polished bit here and there on the engine and im in the middle of polishing the fuel rail , the engine is nearly done now and i'll stick a few piccies on my build thread for approval/disapproval
not sure what to do with the brake setup yet but i'll have to run a bias valve for sure just not sure in what set up yet as the master cylinders have 2 outs and the bias valves ive seen only have 1
