can i use my m20 325i gearbox
jonnyboy
hi, can i use my m20 325i gearbox on a m50 2.5 engine .cheers
e30-EVN
Doesn't a gearbox brace have to be fabricated also?......
As he said mind, all the 6 pot boxes sit 10 degrees out.
The 4 pot boxes sit correct and need no modifying of any part to fit! As if bmw already knew
A 2 door e30 with 8 cylinders, what could be better
jonnyboy
if i was to use the m20 gear box would i be able to use my prop shafts or would i need to change them and am using a e34 525i auto engine if i was to use my m20 gearbox what spigot bearing would i have to use. . thanks for everyones help.
e30-EVN
With m20 box you'd need an m20 spigot bearing and use a 325 prop mate
