Best clutch to use on m52 conversion?
johnmaccow
Iam putting m52 engine and box in my e30 and using the m20 flywheel and starter and have a m20 325i clutch but is it the best one for track abuse?
johnmaccow
Are the m52 clutch kits same as m20 kits?
BMW_E30vert
ive read that the best oem clutch to use is the sachs
BMW_E30vert
if your using the m20 flywheel you need to use m20 clutch+starter
johnmaccow
Got them mate
starting to put it all together now so while its in bits I might as well do it while its all apart.
Sold my E46 and got a 206 1.6 as daily now so missing the power so its really motivated me into sorting it.
BMW_E30vert
good luck mate make sure you use m20 flywheel bolts and the washer when you put the flywheel on, im building a 3.0 stroker collecting the m54 block tomorrow cant wait to get started
johnmaccow
Thats my plan for next year mate .
What washer do you mean?
BMW_E30vert
its no.10 in the diagram below
http://realoem.com/bmw/showparts.do?mod ... g=11&fg=20
best to put a wanted ad up, took the dealers a week to order one from germany just make sure its from a manual car.
Jozi
I don't suppose you would measure how thick the washer is while you have it of the clutch? I have a autobox on thats much to thick and needs machining down.
Dont forget to have it lightened
BMW_E30vert
jozi the washer is 3mil thick
Jozi
Thanks for checking it for me!BMW_E30vert wrote:jozi the washer is 3mil thick
