m50 wiring loom ? e34 or e36
knuckledragger
Post Thu Feb 10, 2011 12:58 pm
hi do any of you no witch wiring loom is used when fitting an m50 into an e30 i fitted a m50 in to mrs touring but i just removed all convertion from an other e30 and the wiring loom has been badly repiared and extended i want to put a stock engine loom in to it is it the e34 or e36 i think it is the e36 as the ecu is in the same place as e30 but dont want to buy the wrong 1 thanks any help is welcome
e30-EVN
Post Thu Feb 10, 2011 2:17 pm
Mines an e34 loom mate, ecu drivers side. I had to extend a couple of wires so the ecu would reach stock (e30) position properly.
Isn't e36 loom with ecu on pas side?
