m40 gearbox....
shedrool83
^ aw what a bitch lol, hope you have a bearing puller to make life easier
I didn't have one, you should ave seen what I had to do to get mine out
, made it using 2 long bolts and a couple of washers lol. Did the trick though
A 2 door e30 with 8 cylinders, what could be better
shedrool83
Yes mate they can both be used but.....
M40 box =318 or 320 prop (longer front section)
M42 box =325 prop (minus the vibration damper)
if using the m42 box a new m20 spiggot bearing is needed (12mm hole)
With the m42 box I used my 320 linkage yoke, it sits in the hole in the tunnel slightly forward but I overcome this by using a z3 short shift lever rotated 180 degrees.
I'm not sure which linkage is used with the m40 box, I do know that its slightly shorter than the m42 box hence needing the slightly longer 320 prop.
Ant
Ant
shedrool83
rancido64
- Contact:
you have a project thread?shedrool83 wrote:Same here .rancido64 wrote:iirc i've seen other people that have used the m40 box saying that they also used the m20 linkageshth
when i finally do mine i'll confirm this for you as this is the route i intend to go
shedrool83
http://www.e30zone.net/modules.php?name ... c&t=185411rancido64 wrote:you have a project thread?shedrool83 wrote:Same here .rancido64 wrote:iirc i've seen other people that have used the m40 box saying that they also used the m20 linkageshth
Just about ready to drop in the lump so not much happened really yet.
rancido64
- Contact:
/subscribed
i need to keep an eye on as many of these conversion threads as possible so i hopefully can learn from everyone else's mistakes and not have any niggles along the way with mine
(yeah right haha)
(yeah right haha)
