Rubber gearboxmounts
hulstijn
Post Tue Dec 21, 2010 10:54 pm
Hello,
I'am swapping my M40b16 for a M50b20 from a E34. At the moment I have the entire list completed:
- E28 M5/535i rubber engine mounts
- Radiator from E36
- Differential 3,64
- Exhaust cat. E36
- Engine mounts E36
But now I need the right transmission mount rubbers. I'm using the E34 M50 gearbox, but which rubbers do I need? I've heard that the E21 320(i) are the best. But which mounts do I need exactly? What are the correct nummers so I can order them at the BMW dealer.
With kind regards from the Netherlands
e30-EVN
Post Tue Dec 21, 2010 11:00 pm
Radiator from E36
ive used an e36 328 rad, works great with no bother 8)
Engine mounts E36
you have listed the right rubber mounts, you need 2 of the hockey puck style ones tho! and its 6 pot e36 engine 'arms' you need mate
and another thing.... why bother with the cats?? your car is pre cat so you can get away with it :)
as for the gearbox mounts, im sorry but i cant help with that as im running an m42 box for which ive used e30 gearbox brace and rubbers - Ant 8)
hulstijn
Post Tue Dec 21, 2010 11:20 pm
e30-dk wrote:
Radiator from E36
Engine mounts E36
Thanks for your answer. But in Holland we have some restrictions for the sound (dB). So I need a mid-demper or a cat.
I'm very interested in the gearbox mount rubbers. Can somebody help me ;)?
e30-EVN
Post Tue Dec 21, 2010 11:31 pm
no worries, i understand with the noise restriction. bit of a bummer mind ay.
im sure someone will be able to help you mate , your in the right place 8)
