What's the difference?
Duke137
Post Fri Nov 05, 2010 6:02 pm
One for you lot in the know?
http://www.realoem.com/bmw/showparts.do ... g=11&fg=35
Which thermostat do I need as there are two part numbers....
I have a 1993 M50 vanos engine from an E36 I bought the engine and ancillaries off ebay
My plan is to replace all the cooling system parts and gaskets with new as these are the obvious trouble spots of the M50 engine. I'm buying some bits off ECP but I want a BMW thermostat
Cook318IS
Post Fri Nov 05, 2010 8:12 pm
11537511580
Thats the one for the 88 degree thermostat (says 88 CEL on the webpage), it will help your engine run cooler compared to the other 'stat
:thumb:
