Front M52 Manifold...
stup86
Post Fri Oct 29, 2010 9:31 pm
Does the front (longer) M52 manifold need to be modified? Mine seem to touch the steering rack and theres no way I could connect the rest of the exhaust to it.
I'll get some pics up if it helps.
Regards
Stu
Parts needed:
M40/M20 ignition coil with high voltage lead
Post Fri Oct 29, 2010 9:45 pm
You can heat/bend it, I usually just chop it and reweld at a slightly different angle
