can some1 tell me what this is?
e30-EVN
Post Fri Oct 29, 2010 12:43 pm
Near where the maf plugs in there is a 2 pin plug, what is this for? Does it plug somewhere on the airbox and because I'm not using 1 (abs!) What do I do with it?
Post Fri Oct 29, 2010 12:47 pm
It is a spare terminal, can't recall what for, think it gets used if your car has a cat
Post Fri Oct 29, 2010 12:48 pm
Can you clarify which engine loom this is on? M50, M20?
e30-EVN
Post Fri Oct 29, 2010 1:07 pm
Its M50 engine and I won't be using cats
Post Fri Oct 29, 2010 1:24 pm
Fuel tank vent valve. Leave it loose or cut the wires back making sure you remove the live right up to the common joint up near the bulkhead
e30-EVN
Post Fri Oct 29, 2010 1:45 pm
Okay cool, think i will just leave it loose and cable tie it somwhere nice, just to check tho for my own piece of mind,, its the 2 pin plug which branches off the maf plug wires? Cheers
Post Fri Oct 29, 2010 6:19 pm
Yep, 2 wires, Red/White and a Brown
e30-EVN
Post Fri Oct 29, 2010 6:45 pm
Yeah that's it, thanx dan. Think I will do as above, leave it loose and cabel tie out of the way. Nice1 mate
