Just tried to get a price for a throttle cable and was asked what length the cable is?
I was given 2 choices:
From memory 635mm or 1170mm.
Anyone know which one I need? I'm thinking 1170.
Regards
Stu
Throttle cable length for M50
stup86
Parts needed:
M40/M20 ignition coil with high voltage lead
1170 indeed
stup86
and just to confirm, it is from the E34 525i right?
Parts needed:
e30-EVN
From an e34 with an M50 engine mate
A 2 door e30 with 8 cylinders, what could be better
Yep, that's what I'm using. As said above, make sure it is an M50 525 car you order the cable for not an early M20 carstup86 wrote:and just to confirm, it is from the E34 525i right?
