Have I got my shopping list right?
jimf
Wed Sep 29, 2010 12:49 am
Been trawling all night now and made this list, please let me know if i have missed anything or got anything wrong. Also i'm a bit confused as to which gearbox, diff and propshaft to use. The ones from the 325i recipient car would just be too easy i suppose :?
Useable bits on recipient car (E30 325i)
Gear shifter
Propshaft bearing (reversed)
Exhaust
Gearbox and diff ??
Bits from donor car(E36 328i)
Engine :roll:
Manifold
Radiator
Fan
Steering rack
Gearbox, diff and propshaft???
Other bits to source
E34 M50 sump 525i/520i??
E34 Steering UJ's X2
E28 M5 engine mounts
E30 320i gear shift rods
E36 318i air con fan temp switch
Extra E30 radiator mount
Clio servo
Custom made PAS pipes
(from DanThe):
Custom engine loom
Custom fan loom
Custom splined steering shaft
Many thanks for input
do-drift-1
Wed Sep 29, 2010 3:31 am
heya mate sorry to jump on this thread but are these the things i would need to put an m52 into my 325i??
jimf
Wed Sep 29, 2010 11:22 am
Thats what i'm aiming for so just need to wait and see if the guys can tell me if it is correct or not
Wed Sep 29, 2010 6:00 pm
jimf wrote:Been trawling all night now and made this list, please let me know if i have missed anything or got anything wrong. Also i'm a bit confused as to which gearbox, diff and propshaft to use. The ones from the 325i recipient car would just be too easy i suppose :?
Gear shifter - Yes
Propshaft bearing (reversed) - Did not need to reverse with M42 gearbox
Exhaust - Yes
Gearbox and diff ?? - Diff if you are going to use an E30 gearbox. On the gearbox front, I would either use a 318is box or use the E36 gearbox if it is a manual. - reason being the 6 pot E30 gearbox will sit at the wrong angle and you'll have to bodge the gearshift mechanism
Engine :roll: yes
Manifold Yes
Radiator - yes
Fan - if it is the air con fan, don't use the viscous fan
Steering rack - big yes!
Gearbox, diff and propshaft??? - if it is a manual, use the E36 gearbox, I can't remember what prop you have to use though. The E30 diff will be no good and you will need to get the guts of the E36 diff swapped into the E30 casing.
E34 M50 sump 525i/520i?? + oil pick up pipe & dipstick tube
E34 Steering UJ's X2 - yes
E28 M5 engine mounts - yes
E30 320i gear shift rods - yes (if using M42 gearbox)
E36 318i air con fan temp switch - should already be one in your E36 rad.
Extra E30 radiator mount - yes for passenger side
Clio servo - yes
Custom made PAS pipes - yes
+ E30 brown temp sensor
+ Early M50 325i air box (unless you want to use a cone filter)
(from DanThe):
Custom engine loom - yes
Custom fan loom - yes
Custom splined steering shaft - yes
Added replies to original post
jimf
Wed Sep 29, 2010 10:20 pm
Thats excellent, thanks. Just a bit unclear about the propshaft and diff if i use the E36 gearbox?
Cook318IS
Wed Sep 29, 2010 10:24 pm
dont forget about grabbing all the ews bits from the donor car too!
Propshaft to use with the e36 gearbox is the 328i proshaft with an e30 centre bearing put on the wrong way around. The diff ratio needs to be between 2.91-3.25 really (i have a 3.25 in mine). You also need different gearlinkage and gear lever cradel/holder doodah (i used a e36 325i lever carrier jobber with the e36 328i linkage if i remember correctly)
HTH
jimf
Thu Sep 30, 2010 1:10 am
OK great, so E36 box and shaft. Now i don't know how you would know what diff has what ratio?
jimf
Thu Sep 30, 2010 8:06 pm
So is the 328i diff useable?
