S52 cams
Jozi
Post Fri Sep 24, 2010 6:07 pm
Anyone here got any lying about :D
When looking for these is it just the camshafts you need (both obviously) or do you need the tray as well?
What do they normally go for? I see 300dollar intake or exhaust cams on ebay.com yet I've heard they were (reasonably) cheap?
Post Fri Sep 24, 2010 6:15 pm
£250-£300 is about going rate for them from what I've seen.
Could do with a pair myself
Jozi
Post Fri Sep 24, 2010 6:17 pm
I'm planning ahead a little. Engine is on a stand at least, where it will stay for months I'm sure. I don't even know if the engine runs yet :)
Jozi
Post Sat Sep 25, 2010 12:55 am
Anyone know anything about pink top injectors? On the off chance I sent someone a pm who had cams advertised in april and he still has them and pink top injectors?
Post Sat Sep 25, 2010 1:01 am
328 M52 injectors are pink
Jozi
Post Sat Sep 25, 2010 1:03 am
What about the e39 528 m52? Likely I wont need them anyway
Post Sat Sep 25, 2010 1:11 am
Can't see there being any difference, have you not got injectors with your engine? They are visible if you remove the 2 10mm bolts holding the cover where the inlet manifold meets the head
Post Sat Sep 25, 2010 9:44 am
Got a set here if you need some
Jozi
Post Sat Sep 25, 2010 10:08 am
I do have injectors, just the guy offer me these pink ones as well as the cams.
Do I just need cams or do I ask him for the tray as well?
Their going cheap as well :)
