Worthwhile M50 mods
LondonTom
Wed Aug 04, 2010 1:55 pm
I have tried to search, but not found anything.
Any advice would be appreciated - just simple mods please.
tom
Dave_M3
Thu Aug 05, 2010 12:00 am
an M52 block and head winkeye
Phill172
Thu Aug 05, 2010 9:13 am
M20 flywheel all day long and lighten the **** out of it!
Underdrive pulleys are great too
other then that i cant say a huge amount more bolt on things,
exhaust manifolds are pretty good already if your using the tubular style ones, and exhaust is always good to look at, iv only noticed a gain on my last one, and air filter if you do get a really good feed to it
hope it helps
LondonTom
Thu Aug 05, 2010 11:33 am
Phill172 wrote:M20 flywheel all day long and lighten the **** out of it!
hope it helps
Thanks mate - it doesnt have the tubular manifold.
It's using an m3 box, so will look into whether I can use the m20 flywheel.
tom
Dave_M3
Thu Aug 05, 2010 1:37 pm
You can use the M20 flywheel no problem once skimmed and lightened and get an M20 starter.
Alternatively if you want a meaty clutch you cold use a lightweight flywheel from BBB and an M5 clutch.
LondonTom
Thu Aug 05, 2010 2:17 pm
Dave_M3 wrote:You can use the M20 flywheel no problem once skimmed and lightened and get an M20 starter.
Thanks mate.
