Right so ive nearly got the c101 all connected up using the list for M50B25 in the wiring sticky.
Some pins and wires left over, this is only a track slag so if i dont need it happy days..
M50 C101 pin number on left and problem on right.
1=missing on m50 - where does wire from pin 2 on e30 go?
2=missing on m50 - where does wire from pin 10 on e30 go?
8=missing on m50 and pin 12 missing on e30
14=pin 14 missing on e30
15=pin 15 missing on e30
20=pin 9 missing on e30
24=pin 8 missing on e30
hope that makes sense any help much appreciated want to hear the damn thing start..
C101 Wiring Help!!
E30Charlie
E30Charlie
Cheers will, if u could help identify these 2 connectors in the pics would be great, they both come from the trucking by the starter, also is there anything to hook up to the 2 flywheel sensors on the m20 gearbox? and do i have to run a power lead from the terminal by battery tray to the starter?
E30Charlie
Cheers will, i suspected the top 1 was an auto gearbox plug, but will check the colours 2moro, also for the 4 pin plug. if it is an o2 sensor would that be for the lamba sensor on manifold?
and the heavy power cable is that to the studed terminal in the middle of starter solenoid (e30 starter)
