Something isn't right
stup86
Sun Jul 11, 2010 8:15 pm
Well today I got my M50 fitted.
But something isn't right... and my suspicion points to some incorrect rubber engine mounts
The mounts:
Here's the problems
Shifter arm doesn't line up
Inaccessible heater matrix hoses:
Space at back of engine, or lack of it (It's so tight that I can't fit the plastic covers on!)
So what do you lot think - wrong mounts?
Parts needed:
M40/M20 ignition coil with high voltage lead
lloyd-m50-e30
Sun Jul 11, 2010 8:53 pm
What box and prop-shaft are you using??
I fitted a m50 in to mine and have been using it daily, I had to customise the mounts because the engine was to far forwards. I have seen them done like that and they sent the matrix pipes through and connected them up in the car and had to adapt gear linkage.
stup86
Sun Jul 11, 2010 9:03 pm
525i ZF gearbox and 328i prop.
The prop isn't connected yet.
Parts needed:
monkey
Sun Jul 11, 2010 9:05 pm
have you got the alloy mount with the earth point on it fitted to the o/s of the n/s ? just looked at mine and the alloy mounting arms on mine are different to yours i am using e36 ones
stup86
Sun Jul 11, 2010 10:09 pm
Nearside mount:
Offside mount (with earth strap):
The mounts are from an E36.
Parts needed:
Sun Jul 11, 2010 10:18 pm
Those look like E34 rubber mounts to me?
Do you have the gearbox bolted up on the mount? With the mount off the engine will tilt back into the bulkhead, looking at the positioning of the engine mounts id say there is nothing wrong.
Which linkage is that?
stup86
Sun Jul 11, 2010 10:23 pm
In those pictures the gearbox isn't bolted up - it's being supported by a jack but it can be pushed higher.
The linkage is 'apparently' an e36 325i linkage.
So the mounts aren't the right ones?
Parts needed:
stup86
Sun Jul 11, 2010 10:29 pm
I still have the mounts from the e34 donor and they are different to the mounts I've used.
Parts needed:
I dont know, what mounts are they?
There are two types of E36 325 linkages, one is cranked over to the left where the shifter mounts, the other is straight
stup86
Sun Jul 11, 2010 10:32 pm
DanThe wrote:There are two types of E36 325 linkages, one is cranked over to the left where the shifter mounts, the other is straight
Didn't know that!
I think I have a 'cranked' one. What one do I need?
Parts needed:
stup86
Mon Jul 12, 2010 7:10 am
DanThe wrote:I dont know, what mounts are they?
Not sure. I got them off Jhonno. I just put up a wanted ad for mounts suitable for M50 and those are what I got.
Parts needed:
penton08
Mon Jul 12, 2010 5:35 pm
if the mounts came off jhonno i would say they are the right ones!! they can be "adjusted" a little by rotating the rubber bit as the threads are offset. not enough to get your selector lined up tho!
stup86
Mon Jul 12, 2010 6:26 pm
I hope so. I'm on holiday tomorrow so I'll sort it out when I get home. Hopefully just a new selector is needed.
Parts needed:
stup86
Mon Jul 12, 2010 9:45 pm
Does anyone have some pictures of the 2 types of e36 325i linkage?
Parts needed:
blue30
Mon Jul 12, 2010 9:54 pm
I turned that top heater matrix pipe 180 degrees on mine so it angles slightly down instead of up - theres just enough room then. Think that's what most people have done.
stup86
Wed Jul 28, 2010 10:36 pm
blue30 wrote:I turned that top heater matrix pipe 180 degrees on mine so it angles slightly down instead of up - theres just enough room then. Think that's what most people have done.
Didn't know that - I'll have to do that!
Parts needed:
Wed Jul 28, 2010 11:23 pm
There's a little indexing pin to cut off.
stup86
Thu Jul 29, 2010 6:43 am
Brianmoooore wrote:There's a little indexing pin to cut off.
OK, i'll have a look for that later.
Parts needed:
stup86
Thu Jul 29, 2010 7:18 pm
It would appear that I have a straight gear linkage and not a cranked one.
Can anyone tell me if the cranked gear linkage is a tad shorter that the straight one?
Parts needed:
