M50 B28?
320ise
Post Mon Jun 21, 2010 9:31 am
What parts are needed from a dead or should i say cooked! m52 b28? if anyone could advise me of a list of parts to get and an machine work that would need doing to the block or bores etc i would be very greatfull!
its going in my e34 as current engine is ok (m50b25) but now on nearly 250k and as hard as it is trying nothing lasts for ever!
thanks.
E34 ///M5 THE BEST BMW EVER BUILT?
Post Mon Jun 21, 2010 9:46 am
Basically a bottom end, you wont need any machining unless you fancy having the block face skimmed, but you will want to fettle the bores with a honing tool to take out any ridges left by the shorter stroke of the 2.5
pm me if you need a bottom end as I have a minty mint one ripe for an M50 conversion still in a useable alloy block
