Rad Fan Switch
JPMC1977
Post Tue Jun 01, 2010 2:24 am
nearly finished!!
But as ever in reality will never be....longest swap in history.
I've a breakers business available to me but most parts have cables snipped etc. as everything lies on shelves.
I've fitted a fan and now need the fan switch too.
Its an M14 1.5 and as I've read on here 88 deg. is a starting point.
Any idea as to what manufacture fit this to which rad? Motor factors dont have one in stock.
If I can find one off a rad in the breakers its mine!! and I should have the connector fan side too.
Motor factors said it was a rover 400 fan switch..
Can anyone confirm
Also do I need to fit or swap the brown Temp sender from M20 into the block of the m50b25 under the intake for one of the sensors thats der already.
Thanks in advance
Noog
RoadHazard
Post Tue Jun 01, 2010 5:44 am
I believe the rad temp switch you want is from BMW E36 318. It's a dual temp switch 80/88 C.
JPMC1977
Post Tue Jun 01, 2010 11:43 am
Cheers dude just checked that on oem...
So many ways to bake a cake.....
Bake a nice cake!
Locating e36 318i dual temp switch as we speak to make bmw run cool
Thanks again.
