Does this rad look ok for M50?
stup86
Post Mon May 31, 2010 9:10 pm
It's off a 328i. It's the only pictures the guy has sent so far.
Can anyone tell me if I can use a temp sender on this rad to control an electric fan?
Stu
Parts needed:
M40/M20 ignition coil with high voltage lead
Post Mon May 31, 2010 9:28 pm
That's the kiddy to use. It already has a temp sensor sticking out the side, look on the left of the first pic.
Plug & play mate :)
Post Mon May 31, 2010 9:38 pm
It has a temp. switch, but it's probably one for too high a temp. IIRC, it needs swapping for a 318i E36 one.
stup86
Post Mon May 31, 2010 10:05 pm
OK then i'll tell him that i'll have it.
Btw, what would you guys say was 'fair' for that radiator, price wise?
Stu
Parts needed:
Post Mon May 31, 2010 10:36 pm
£40 is about the going rate for a good condition second hand one, its an aircon type so the best you can get with a side tank 8)
stup86
Post Mon May 31, 2010 10:38 pm
That's alright then as he wants £40 for it.
Glad its the best type.
Cheers guys.
Stu
Dan - Do you make up the wiring 'loom' for an electric fan conversion? (I'm sure I read that you do)
Parts needed:
Post Mon May 31, 2010 10:49 pm
Yeah I do occasionally, I need to do a couple for other converters soon so if I have enough plugs/cable etc I will knock up another
stup86
Post Mon May 31, 2010 10:58 pm
How many GBP's or stellas am I looking at for one then?
Parts needed:
Post Mon May 31, 2010 10:59 pm
£40 is the usual price :)
