Power steering pumps
stup86
Mon May 10, 2010 5:50 pm
Hi all,
Been told on here that I can't use the E34 M50 power steering pump with my E36 rack as I'll blow the seals.
I phoned a guy up about an E36 pump and he said that they were the same at around 100-120 bar or something like that.
Can anyone tell me the difference in the pumps.
I looked on realoem and found that the parts number differ slightly
32411137082 - E34
32411137952 - E36
Stu
Parts needed:
M40/M20 ignition coil with high voltage lead
Cook318IS
Mon May 10, 2010 5:52 pm
i've got an e34 pump on mine and its been fine so far
stup86
Mon May 10, 2010 6:17 pm
Good good,
I don't really want to buy another pump tbh!
Parts needed:
Mon May 10, 2010 8:06 pm
I think it may be the pumps from the E34 tourings which are no good as they have an additional outlet for the self levelling rear suspension and operate at a higher rate, but not 100% on that.
stup86
Mon May 10, 2010 8:32 pm
I knew that the 3 outlet pumps were no good, but I was told that e34 pas pumps were too 'powerful' for an e36 rack as the e34 is used with a steering box?!?!?!
Oh well, if other people are using one with no probs then i'll do the same.
Cheers Lee and Paul
Parts needed:
