A dirty little copy/paste. I'll attempt to add further updates as they happen.
Whoring myself about the interwebs.
I'm not overly wordy so this will be more of a pic dump me thinks.
Donor
Recipient
Not much left of that
Who needs an engine hoist, tow that boat anchor out.
Sweet FA rust
Yay
E46 vs E30 subframes
Modified subframe
Front suspension tacked in place.
Rear end setout
Some guard work to do
Checking for true
Lower sill mod to clear trailing arm bushes
Brake booster and ABS pump/speed signal comp etc in back ground.
Pedals
Casualties
Some rough ideas re flares
Rear seat area cleaned up
I hate fucken sunroofs
Spit NZ styles
Underside fitted
Moving inside HVAC unit HUGE.
Dash is gonna need some work
And this crazy mess
Bootlid controls
Its alive
Cluster
HVAC panel that needs a redesign as the radio no longer has enough depth
E46 column
And one idea for the final look
Thats for looking!!
