what diff. should I use guys?
vanilla112
Sat Feb 06, 2010 3:44 pm
I made an m50 swap on my e30, the engine is a 2.5 24v....done 2.8 by HARTGE I don't really know the power probably around 240 bhp....and my question is what diff should I install.....now I think I have 3.64 open ....but I found a 3.25 LSD and I wonder if it's ok for squeezing the power from the engine. The gearbox came with the engine it's getrag ....and I also wanna ask you if I can install an oil cooler....thanks guys
Sat Feb 06, 2010 6:23 pm
If you are using an E30 gearbox the 3.25LSD may make it a bit lazy with acceleration, but will allow low revs at cruising speeds
If you are using E30 gearbox I'd recommend you try and get a 3.64 or 3.73 LSD
vanilla112
Sat Feb 06, 2010 6:42 pm
I have the e36 gearbox that came along with my engine...
leeparkes
Sat Feb 06, 2010 6:45 pm
vanilla112 wrote:I have the e36 gearbox that came along with my engine...
The 3.25 ratio LSD will be fine with that gearbox
vanilla112
right now I have 3.64 open and my gears are too short that's why I want a new diff ratio to go long in 1st and 2 gear....but I don't know which suits my needs
vanilla112
Sun Feb 07, 2010 3:12 pm
ok guys thanks for the advices
//Rocky
Sun Feb 07, 2010 3:15 pm
vanilla112 wrote:ok guys thanks for the advices
I've got a 3.73 LSD in perfect working order, if you decide that is what you want :)
Sun Feb 07, 2010 9:18 pm
3.25 is still going to be on the short side with 240 bhp behind it. It'll be the equivalent of 4.01 with an E30 gearbox.
2.95 is more like what you want. This will give very similar speeds in fourth gear to what you now get in fifth.
vanilla112
Mon Feb 08, 2010 12:31 am
you think it's to short 3.25? but it will make a difference from what I have now?....cause I don't really think I can find that ratio around my zone here....the 3.25 I found it at 200eur....
Kos
Mon Feb 08, 2010 12:34 am
the 3.25 will be almost perfect, top speed will be about 140mph and you will get there very quickly........
www.pukardesigns.com
IG Pukar.Designs
Mon Feb 08, 2010 12:38 am
The 3.25 will give you gearing similar to standard 115 bhp 4 pots.
Kos
Mon Feb 08, 2010 12:42 am
to the original poster....
drive 328i e36, then decide if you want it to be shorter, but remeber the e30 is about 200Kg lighter.
IG Pukar.Designs
Aberdean
Mon Feb 08, 2010 8:02 am
Kos wrote: drive 328i e36, then decide if you want it to be shorter, but remeber the e30 is about 200Kg lighter.
my point too...my 328i feels slow (it isn't though) and i've elected to add a short shifter to E36 gearbox because they are same as M3 iirc and then mate my 328 prop to a E30 325 diff/prop...for the first run i'm keeping the E30 316 diff in there (unless it blows LOL) to see what happens :twisted:
I'm putting a 2,8 imto mine and i have similar turmoil, good luck
vanilla112
Mon Feb 08, 2010 10:31 am
I think I will mount the 3.25 diff see how it turns out to be ...because at the moment I don't have another option and if it's not what I need..... I will return it to the guy( he's a friend of mine)
Aberdean
Mon Feb 08, 2010 10:38 am
vanilla112 wrote:I think I will mount the 3.25 diff see how it turns out to be ...because at the moment I don't have another option and if it's not what I need..... I will return it to the guy( he's a friend of mine)
Don't quote me, but I've been told one can run an E36 diff on the E30???
vanilla112
Mon Feb 08, 2010 10:45 am
zonda man ...I don't have a clue what you're saying ...I asked a question for the guys that know what I'm talking about ...go ant tell your stories to someone else....cheers
Kos
Mon Feb 08, 2010 10:54 pm
Aberdean wrote:Don't quote me, but I've been told one can run an E36 diff on the E30???
the internals can be swoped over, but mounting the diff is different ball game
a small case diff from your e30 will be too short, and shit it self
IG Pukar.Designs
tomcat2040
Sat Feb 13, 2010 11:49 pm
Go all the way and just get a 4.1 :mad:
Kos
Sat Feb 13, 2010 11:55 pm
tomcat2040 wrote:Go all the way and just get a 4.1 :mad:
shut up
an utterly useless ratio with that gearbox
IG Pukar.Designs
knightmare
Sat Feb 13, 2010 11:57 pm
i am mulling a change of dif myself
this link should give you an idea of what to expect from different gears and revs
http://www.unixnerd.demon.co.uk/revs.html
final drive = diff ratio
JamOnIt
Sun Jan 30, 2011 1:18 pm
What would the tag on a diff 2.93 read, is it "307 0937"?
invader
Sun Jan 30, 2011 7:49 pm
im selling a E30 M3 3.25 diff
PM me if your interested .
