Because when I've checked them they look a bit rusty...StefanAnghel wrote:Thank youBrianmoooore wrote:DME, lambda sensor heater and fuel pump.
Could them be my problem if they are not working properly!?
Trying to nail this idle problem
StefanAnghel
randomspeedfreak
shot in the dark here but if your lambda heating relay isnt working correctly the lambdas could not be sending a correct signal to the ecu?
.....actually i guess that would that only affect the engine from cold
StefanAnghel
Thank you... My problem is mostly when cold...or sometime random when warm and rolling to roundabout on neutral...but just sometimes not always...randomspeedfreak wrote:shot in the dark here but if your lambda heating relay isnt working correctly the lambdas could not be sending a correct signal to the ecu?
StefanAnghel
Almost getting to an end with my problems...I've took everything off (air hoses) and sealed them using thread tape and forced them in...cleaned again the ICV and seems better...the only problem is when the engine warms up... The idle goes up and down...from 500 to 900...
I've changed the lambda back to the original one as i've heard that the aftermarket ones might not work as they suppose to do...
Any ideas?!
Thank you
Any ideas?!
Thank you
StefanAnghel
I'll probably end up with with bits for 2 engines...
I've got 2 lambda's, 2 ICVs, 2 TPS... Today I've spend 5 hours playing with them...
Only with ICV I can see a difference:
With one the engine starts but stalls as not enough air,
And with the other one the Idle jumps from 600 to 1400...done the change between them twice now...
With the ICV that the engine idle plays up if I disconnect the MAF connector the idle settles but the engine sounds rough
Any idea!?
Thank you
Any idea!?
Thank you
StefanAnghel
Come on 24v people! I need help
randomspeedfreak
ive read the whole thing and racked my brain-got nothing
isit making full power on throttle?
StefanAnghel
Yes
goes up to 7000rpm...
I bet is the ICV...at least I hope it is
StefanAnghel
I was wrong...changed the ICV, the MAF, the TPS and looks like might be the Lambda...with the MAF connected the idle goes up and down 750-1500 RPM and when I disconnect it the idle settles but runs rich...StefanAnghel wrote:Yes
I'll change the lambda tomorrow and see what's happening...
rich318i
mine came up as lambda on bank 2 one of the wires were fook but never had an idle problem like your saying. could it be a duff a engine temp senor. best thing to do is to pay someone to put there computer on it mate and see what faults come up
StefanAnghel
I need Dan's help! Will the codes will show up?!
rich318i
yeah get someone with a snapon or any good diagnostic computer and that will tell you whats what not just codes even the part thats not working. you did wire up the diagnostic wire to the c101 plug?
StefanAnghel
I'll do that then... Thanks
