As I did, see my post in the first page.DanThe wrote:You are better off getting an E30 prop front half shortened and an E36 large flange welded on the front end of it
6 speed box
jimbom30cab
- Tech 1 freak
Ok thanks, did you need to adjust the gear selector rod length?
jimbom30cab
- Tech 1 freak
Yes it fits the 5 speed,box perfect but sorry i am keeping mine
If you mean the link bar between the stick and the gearbox then yes I had to cut it twist and shorten it.
jimbom30cab
- Tech 1 freak
thanks Appletree, that's what I meant. Would you have a pic of yours after the "adjustment"
jimbom30cab
- Tech 1 freak
Your not going to believe this
A 318i auto prop is a perfect fit at 137cm
Just need to re use the smaller gb output shaft
Bummer !
Bummer !
craigieeb
happy days, I can see the price of those going up from now onjimbom30cab wrote:Your not going to believe this
Bummer !
could you not just cut the flange off the end of the prop, weld the larger one on,
so you can use the bigger/stronger doughnut......
M50 Turbo!!!
I shall say no more
jimbom30cab
- Tech 1 freak
yup you could do that, i guess it would be ideal to then balance it
just writing the for sale add out now
M40 auto prop, fits M52 speed perfectly.
