E30BeemerLad wrote:OK, shopping list, using your car.
M50/52 engine, (budget for doing a water pump change)
E34 sump, oil pickup pipe & dipstick. (new sump gasket regardless)
E36 engine arms
E28 M5 rubber engine mounts
M52 exhaust manifold
Use your own rad & buy the thermo switch which will bolt to the side of the rad
Electric fan - air con fan from E36 or E34 will do fine
Clio servo from 2000 onwards clio
Loom for the electric fan £40 from DanThe
Converted engine loom £100 exchange from DanThe
M20 flywheel & clutch
320 gear selector rod & alloy cradle where the gearstick sits
325 propshaft
Diff - your choice
Coding plug for 6 pot car fitted into your cluster
If your car has ABS then you'll have to use a cone filter
Fit an E36 rack & modify pipes
As to how you get a lot of the bits, depends really, I'd look at getting a complete car as the cheapest way of getting the engine (assuming there is stuff worth selling on from the car) -E36 is probably a better bet for resale of morsels. It is important to hear the engine running and see how it goes unless you are buying from someone you trust.
Hope that helps
